1995 Chevy Cavalier Error code
167,000 MILES • 4 CYL • FWD • AUTOMATIC
JENNIEJO69
Code 15...Pass circuit initiator resistance high...what would that be? I assume a sensor of some sort, in the passenger seat, as the SRS light is on.
Aug 13, 2010 at 9:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Code 15 indicates a faulty coolant temperature sensor, nothing to do with the restraint system. You need a special scan tool to retrieve the SRS trouble codes.
Aug 13, 2010 at 10:12 AM
JENNIEJO69
Thanks for the info bluelightnin6...we were using a scan tool and it came up with the error code 15...Pass initiator circuit resistance high...we were scanning for the SRS error code at the time. I did not personally run the scanner, but the person who was using it, I am pretty comfortable with his knowledge of how to use it correctly. I had done a little searching and found the error code 15 has something to do with the coolant system, so now I am baffled...will have to go back and re-read the code and see if I missed something! Thanks again!!!
Aug 13, 2010 at 10:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ok i see , its code 15 of the SRS not code 15 of the engine. some information is below on the SRS code 15..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2580.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_836.jpg
Aug 13, 2010 at 11:48 AM
