my 1995 chevy cavalier,i pulled up to the a stop light,it was running well,the check engine light was on,and when i went to go, seems liked the tranny was slipping because barely could get over 10 mph so pulled over to the side shut car off, waited a few minutes,restarted the car and then shifted it into gear, got no response in any gear, i reved it up and it moved a little bit, did the same thing in reverse,you think it could be a speed sensor not sure if this car has one? or is the tranny is no good?
Apr 21, 2008 at 12:30 PM
