1995 Chevy Cavalier About 1995 Chevy
218,000 MILES • 4 CYL • 2WD • AUTOMATIC
95CALVALIER
I would like to know that I brought a car with 218,000 miles. Should I replace all the parts? Should I get some parts from the local junkyard? I need this car to performed at it maximum potential. What should I do?
Oct 22, 2009 at 5:48 PM
MMPRINCE4000
  • 8,548 POSTS
Start here:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Also inspect belts, brake rotors, calipers, shocks/struts, exhaust system, cooling system, hoses, plugs, wires.
Start with a complete inspection before replacing parts.
Oct 25, 2009 at 1:26 AM
