By the turn signal mechanism, do you mean the turn signal multi-function switch? If you have replaced the switch and the turn signal flasher relay then there must be a fault in the wiring either to the switch or the relay.
SPONSORED LINKS
Thursday, June 11th, 2009 AT 9:51 PM
