1994 Chevy Cavalier overheating
DIRTGIRL208
Engine Cooling problem
1994 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
my cavaleir is over heating......quickly. The thermostat is good. Got the fan working...all the initial things to check have been. A friend mentioned maybe a head gasket problem. I thought the car wouldn't run if this was the case but apparently It would just over heat quickly...also I heard that if it was the water pump I would hear it. Could you please tell me the process of elimination to make sure I don't miss something before I have to pay big bucks at a shop??
Aug 9, 2008 at 8:03 AM
REDBONE
  • 106 POSTS
check your oil to see if it's milky,if the oil is milky then the head gasket needs replaced
Nov 10, 2008 at 10:16 AM
