Remove the oil sending unit and install a mechanical gauge. Start the engine cold and let it warm up to normal operating temperature. Check for proper oil pressure.
Post results and I will follow up.
Do NOT drive vehicle until issue is fixed or severe damage will occur to internal components of engine.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Monday, January 19th, 2009 AT 11:33 PM
