1994 Chevy Cavalier No Brakes
134,000 MILES • 4 CYL • FWD • AUTOMATIC
DIGIDOGG69
I use the car one day the brakes were working fine the next day i started the car and th brakes when stright down .I replaced thae pads and bleed them still no brakes changed master and blrrd them again and still no brakes. ihave checked for leaks and cant find any what is wrong
Jun 17, 2010 at 3:32 AM
FACTORYJACK
  • 4,159 POSTS
Did you bench bleed the new master cylinder? Can you pump the pedal and get pressure to build. If you can do that, build pressure and crack lines at the master cylinder first, to release the air. Then I would continue with a full bleed.
Jun 19, 2010 at 10:44 AM
