1994 Chevy Cavalier Multiple burnt out tips on Number 3 cyl
WOLFBROOD
Electrical problem
1994 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I have a 1994 Cavalier 2.2L 4 cylinder. About a month ago, I replaced all the plugs on the engine, along with the plug wires and Ignition coil. The reason was that it was missing. I noticed when I pulled the plug on the cylinder that is 3rd from the left, it was fouled with oil. I also put in a fouler cover to stop this. But since then, I've had a worse problem with it now burning out the tip on that same cylinder of it burning the tip on the plug completely out. Any Ideas on a fix to this?
Oct 21, 2009 at 6:30 AM
DOCFIXIT
  • 18,828 POSTS
Oiling that much no chance keeping plug clean. Fouler not going to work in 2.2 cumbustion chamber it will hold oil and detonation shock will destroy electrode. See if you can get a plug with higher heat range
Oct 21, 2009 at 8:38 AM
