1994 Chevy Cavalier Losing brake fluid and pedal pressure
123,000 MILES • 4 CYL • FWD • AUTOMATIC
BOBK53166
I am hearing a noise like something is catching when the wheels are turning. I have added fluid 2 of the last 3 days. Pedal is going to the floor. Where would I start?
May 10, 2009 at 2:29 AM
RHALL77
  • 3,361 POSTS
look under the master cylinder and see if it is leaking. most likely you have a wheel cylinder leaking in the rear brakes. see if behind the wheel is wet
May 11, 2009 at 6:43 AM
