1994 Chevy Cavalier leaking engine coolant
BIGDADDY8572
  • 1994 CHEVROLET CAVALIER
  • 4 CYL
  • 165,000 MILES
I have a small engine coolant leak, can I add a synthetic antifreeze to seal the leaky hose or do I need to replace the hose even though it leaks very slowly
Wednesday, February 27th, 2008 AT 5:13 AM
BLACKOP555
  • 10,371 POSTS
You could but you should replace it, it will eventually wear down around it since that is now a weak point and the hose will blow, where you will be at when it blows I do not know. But hopefully it wont be out in the middle of no where.
Wednesday, February 27th, 2008 AT 7:14 AM
