1994 Chevy Cavalier Idle Issue
102,000 MILES • 4 CYL • FWD • AUTOMATIC
NUCLEARPUSHER
  • 7 POSTS
I seem to be having an idleing issue with my car. I recently replaced the head gasket on my vehicle. Before i did this it seemed to have an issue at idle. I put the vehicle in any gear but a forward gear and it would idle ok with just a small feeling of a miss. In drive or a forward gear it would idle so rough it would shake the dashboard. I changed the head gasket because it had a small seep at the drivers side front corner thinking that lower compression in that cylinder may cause this. When i completed this job, it still runs the same. Since i have put on a new tps, wires, plugs, iac, and map sensor. It still does the same thing. The ignition module tests good, and i have changed the coil packs as well. It seems to be "loading up" with fuel while running at an idle and all the plugs that i take out look the same. A lil sooty, and dark. We had it on a snap-on code scanner and we do not have any codes showing up. In your best opinion, do you think i may have a computer issue?
May 12, 2009 at 1:37 PM
RHALL77
  • 3,361 POSTS
you may have a injector leaking. take it to your local shop they will have the tools to test it.
May 13, 2009 at 12:44 AM
NUCLEARPUSHER
  • 7 POSTS
It happens on all 4 cylinders at the same. I had all the injectors replaced with new ones from GM. There are no no leaks and the scanner shows all firing at the correct time. I used a noid light for that. Also I do work for a garage, and all the tools to test that I have. Which is why i am having such a frustrating time with it
May 13, 2009 at 2:27 PM
RHALL77
  • 3,361 POSTS
what about your temp sensor. what is that reading? also check your connections at the pCM and make sure they are not full of corrision
May 14, 2009 at 1:41 AM
NUCLEARPUSHER
  • 7 POSTS
According to the snap on scanner, temp sensor reads fine and i had the opportnity to try a different engine computer today, Neither one of those worked. A friend of mine is taking it over to garage on saturday. That will make 6 garages including mine in three weeks. hopefully he can figure it out
May 14, 2009 at 12:31 PM
