1994 Chevy Cavalier Idle air control valve
1994 CHEVROLET CAVALIER
95,000 MILES • 6 CYL • FWD • AUTOMATIC
CASSANDRAB
Where is the IAC located on my car, and also how do i go about replacing it?
Dec 7, 2009 at 6:56 AM
MMPRINCE4000
  • 8,548 POSTS
It is on throttle body and has a 4 pin connector on it. Two bolts hold it in place, remove bolts, IAC and gasket. Make sure to disconnect - battery cable BEFORE you remove. This is the part:
https://images.2carpros.com/forum/automotive_pictures/108325_cav_iac_1.jpg
Dec 10, 2009 at 5:36 AM
