1994 Chevy Cavalier Heat doesn't blow strong
166,120 MILES • 6 CYL • FWD • AUTOMATIC
KERLYN
The heat does'nt blow out of the vents very strong. The car has a new blower motor, and all the vacuum lines are hooked up. What little air I get is hot. I get the most flow out of the vents, but whenn switched to defrost or heat, or any other setting the flow is decreased.I've not been able to find alot of info for this problem. your input is apprecited.
Feb 23, 2010 at 7:16 AM
SCOTTY DEE
  • 592 POSTS
Have you checked the blend door for obstructions?
Feb 24, 2010 at 2:18 AM
KERLYN
No that will be my next step. I was hoping for an easy fix. I guess the next step will be to go under the dash and star taken stuff apart and see if it all works right.
Feb 24, 2010 at 4:47 AM
SCOTTY DEE
  • 592 POSTS
Good for you. If you have any questions let me know and I'll try to help you.
Feb 25, 2010 at 9:23 AM
