1994 Chevy Cavalier head gasket repair
RFGARRIS
  • 1994 CHEVROLET CAVALIER
  • 6 CYL
  • FWD
  • 99,000 MILES
Has anyone successfully used 'Steel Seal' to repair a bad head gasket?
I cannot afford $1000 repair
any suggestions?
Saturday, December 13th, 2008 AT 10:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Unfortunately, there is no repair-in-a-tube type product to fix a blown head gasket. Steel seal, bars leak and JB Weld all will work for minor cooling system leaks; however, if you have a leaking head gasket that is consuming coolant you will have to replace it, no way out of it.
Saturday, December 13th, 2008 AT 10:24 PM
BMRFIXIT
  • 19,053 POSTS
I am not a big fan of it
some like it and used it and say it works
I think it will give you more problem later on and will clog the system
and may damage the radiator if instruction not followed to the T
and is in it about $80 the gasket is cheaper
you have to do it your self
Saturday, December 13th, 2008 AT 10:29 PM
