1994 Chevy Cavalier fuel injectors
120,000 MILES • 4 CYL • FWD • AUTOMATIC
SEANLD13
one of the fuel injectors on the cavilier is spraying gas all over the engine ...would this cause the car to die and not start?
Dec 15, 2008 at 6:35 AM
MMPRINCE4000
  • 8,548 POSTS
Yes.
The injector has come dislodged from fuel rail. Remove fuel rail and replace the Orings on each injector. Use a dab of grease one the Orings to make reassembly easier.
Most injectors are held to fuel rail with a small clip, you may need new clips.
Dec 18, 2008 at 1:15 AM
