My engine on my 94 2.2 liter 5 speed cavalier stalls only when the clutch is pressed in and only when the car is at normal operating temperature. I've replaced the idle control valve, map sensor, cleaned the throttle plate, and replaced a bad vacuum line. Nothing has fixed the problem. I was wondering if you guys had any ideas. Thanks
Apr 21, 2008 at 6:37 PM
