1994 Chevy Cavalier engine reving high
SLORRI23
  • 1994 CHEVROLET CAVALIER
1994 Chevy Cavalier
engine was revving very high, like the cruise control was stuck, brake lights came on, car would just go without pushing gas. Then when turned car off, it was hard to start like, it did not start right up like usual. When started, idle very high, put into reverse and let off brake, just went without pushing gas. Put it back into park, idle very high again. Now the car will not start at all.
There is oil and water, temp seems ok. Help, single woman, only car to get to work. Thanks so much in advance for all help.
Friday, June 26th, 2009 AT 7:56 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, June 27th, 2009 AT 2:01 AM
