1994 Chevy Cavalier engine engine coolant
183,000 MILES • 4 CYL • 2WD • AUTOMATIC
KJMBME
some one told me that if i put in red engine coolant my car will heat up faster in the winter times is that true because right know its has the reen color in it the heater core, head gasket all have been changed
the level is all right in the overfill when i checked in the rad looks like there some sort of clumpy stuff on the edge if the rad and on the cap but the fuild has been changed already so what should i do put in the green color or the red if i deside to to a rad flush
Jan 27, 2009 at 1:50 AM
RHALL77
  • 3,361 POSTS
no color has nothing to do with it. does it seem to you that it doesnt heat up fast enough? you may have a thermostat problem
Jan 27, 2009 at 10:09 AM
