1994 Chevy Cavalier Coolant Leakiing
GARR
Engine Mechanical problem
1994 Chevy Cavalier Automatic
I have a 1994 chev cavalier, and it started leaking rad fluid. Took it a mechanic and said it may be a frostbug or cracked engine block.
My question is: is this worth fixing? if not, what price can I charge to get rid of it.
Dec 12, 2008 at 2:06 AM
  • 75,988 POSTS
The engine oil is it milky and also the coolant is it mix with oil ? How did he confirm his suspicion on the block-Did he do a block and pressure tests-
Dec 12, 2008 at 5:13 AM
GARR
i talked to someone this morning and he spoke to the mechanic that was working on the car. The mechanic said that it is a frostplug and they would have to take the engine apart to fix the problem b/c the leak is between the engine and the tranny.
Dec 12, 2008 at 5:51 AM
  • 75,988 POSTS
I see -they gonna have to remove the engine or tranny to replace the freeze plug extensive labor involved-
Dec 12, 2008 at 5:56 AM
