1994 Chevy Cavalier code retreval
112,000 MILES • 4 CYL • FWD • AUTOMATIC
REDBONE
  • 105 POSTS
when i use a code key to access the computer,the check engine light should blink once then blink twice to access,my light won't blink at all.i have the key in the right spot.why won't the engine light blink
Nov 10, 2008 at 9:53 AM
  • 110,251 POSTS
Hi:
Do you mean the ignition key? I believe you need to have a special tool to do that on a 94 cavalier. Stop at a nationally recognized parts store and have them do it. Most will do it for free.
JOe
Nov 14, 2008 at 4:26 PM
REDBONE
  • 105 POSTS
[quote:eec1a07cc7="redbone"]Electrical problem
1994 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 112000 miles
when i use a code key to access the computer,the check engine light should blink once then blink twice to access,my light won't blink at all.i have the key in the right spot.why won't the engine light blink[/quote:eec1a07cc7] i mean when i use a jumper wire and then turn the ignition to on the check engine light doesn't blink
Nov 14, 2008 at 10:11 PM
MASTERTECHTIM
  • 4,750 POSTS
does the light come on steady with the key on engine off? you should be jumping termianal a and b of the diagnostic connector. make sure the black wire has a ground because what you are doing is grounding the other wire putting it into diagnostics. i worked at gm during the nineties and dont recall having one not flash codes before but if yours does not you need to check the wire from the diagnostic connector to the ecm and make sure the wire is not broken or you will need to replace ecm.
Nov 14, 2008 at 10:35 PM
