1994 Chevy Cavalier Antifreeze/Coolant leek
100,987 MILES • 4 CYL • 2WD • AUTOMATIC
NATEMAN109922
I am haveing a problem with a coolent leek coming from around the oilpan near the bottom of the car. I replaced the thermostat with a new oem one. What els could be the problem?
Jul 17, 2008 at 9:32 PM
  • 31,937 POSTS
Hi there,
There are a number of places that the coolant can be coming from, so you should get a cooling system pressure test doe, this will help locate your problem.
mark (mhpautos)
Jul 17, 2008 at 9:59 PM
NATEMAN109922
Hi i found the leek is coming from the oil pan and i have a good amount of coolent in my oil pan mixed with the oil what could this mean?
Jul 20, 2008 at 8:56 PM
  • 31,937 POSTS
Hi there,
You will want to be doing a check for a head gasket problem first as coolant in the sump is usually from a head problem.
Mark (mhpautos)
Jul 20, 2008 at 9:55 PM
