1994 Chevy Cavalier
BLUE LIGHTENING
Engine Cooling problem
1994 Chevy Cavalier 4 cyl Automatic
The last few days my temp gauge would max out, check engine light would come on, then the temp gauge would pop back down to normal. This morning temp gauge maxed out, only this time it did not come back down & then an upper hose blew. Only 2 miles from home & was able to make it. It has been extremely cold the last few days. I am wondering if you think this sounds like I need a new thermostat. If so could you tell me how to fix that? Thanks!
Jan 4, 2010 at 5:59 AM
  • 110,251 POSTS
Are you sure the coolant isn't freezing? Also, it could be the t-stat. You can remove it and check to see if it is working properly.
Here is a how to:
http://www.2carpros.com/dia/test_thermostat.htm
Let me know what you find. Also, make sure there are no leaks.
Jan 5, 2010 at 5:36 AM
