1994 Chevy Cavalier
JKOHL
1994 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
my car is revving very high like the thorttle is stuck and then it will start to idle up and down with the check engine light on replaceed the map sensor and thorttle postiosn sensor still didnt fix it?
Jul 20, 2009 at 8:00 AM
SERVICE WRITER
  • 9,123 POSTS
What codes are showing now?
Are you in an area that the temperture reaches freezing?
THe pcm had been a problem due to the location on these. Water would enter it and crack the case.
Jul 20, 2009 at 10:29 AM
JKOHL
[quote="jkohl"]1994 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
i live in the valley of oregon so doesnt get to cold here the local parts store scanner said low map pressure?
Jul 20, 2009 at 10:55 AM
SERVICE WRITER
  • 9,123 POSTS
HAve you checked for an intake leak? Using carb cleaner spray around the intake gasket area and see if the idle changes.
HAs there been any work done to this just prior to this problem? In particular has the egr been removed at all?
Jul 20, 2009 at 12:46 PM
JKOHL
no worl was done prior to this it just started doing it yesterday it was weird thinking may iac sensor tryed to find a book on it but the local store has none in stock so i could test the map tps sensors for ohms to see if they are bad
Jul 20, 2009 at 4:10 PM
SERVICE WRITER
  • 9,123 POSTS
TPS voltage is .6V t0 4.80 V. I don't know what code number you have so I assume it is this:
https://images.2carpros.com/forum/automotive_pictures/30961_acav3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_acav1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_acav2_1.jpg
If this is the right code and you can't read this, send me an email. Pukenstein@aol.com and I'll send it.
Jul 20, 2009 at 10:29 PM
SERVICE WRITER
  • 9,123 POSTS
The two things I would focus on at this point...actually 3.
1-Be sure the wires and connections are good at the iac, map and pcm. Be sure the harnesses have not been damaged through heat or oil and no corrosion exists.
2-be sure there are no vauum leaks. At the manifold and all rubber goods. Look for any dry rotted, collapsed or opened up lines.
3- Clean the throttle bore with a good cleaner. May need to pick up a bottle brush to aid in this.
https://www.2carpros.com/how_to/how_to_tune_up.htm
Jul 31, 2009 at 10:44 PM
SERVICE WRITER
  • 9,123 POSTS
In an email, the member found the intake manifold leaking. The unmetered air was the vacuum leak.
Aug 3, 2009 at 10:10 PM
