1993 Chevy Cavalier Stalling
62,000 MILES • 4 CYL • FWD • AUTOMATIC
SARGE995
My 1993 Chevy Cavalier has begun to idle rough, it coughs and sputters a bit, but when you come to a stop, you really notice how rought it is. It has started to stall at lights and stop signs, you can start it in park or neutral, but when you put it in drive or reverse, it stalls out again. It runs again after sitting for a little while, what can it be and is it costly? I only bought the car for 200.00 and drive it 2 miles to work. Thanks!
Oct 29, 2008 at 8:04 AM
  • 110,251 POSTS
Hi:
It could be a number of things. If you only drive 2 miles to work, the car never really warms up properly. Therefore it could be a fouled plug. Not expensive to repair. However, it could be a head gasket or a vacuum leak. That can get costly. Check the oil and make sure it doesn't have coolant in it. Also, when the engine is cold, check the coolant for oil contamination.
Let me know if the check engine light is on. Also. you may want to stop at a nationally recognized auto parts store and have them scan the computer for trouble codes. They will do it for free and it may get us pointed in the right direction.
Oct 31, 2008 at 5:20 AM
