1993 Chevy Cavalier overheating
111,200 MILES • 4 CYL • 2WD • AUTOMATIC
SKICOOPS
The car suddenly started overheating. I have checked the cooling fan which seems to be working fine. changed the thermostat, hoses, radiator cap, did a raidiator flush. Somewhat better but still have to be careful. any trip over an hour I have to turn off the a/c periodically to keep the temp down. What more can be done?
Sep 11, 2010 at 7:05 PM
  • 75,988 POSTS
Are you filling the radiator up with coolant while the engne is idling or engine not running open cap and just fill it in??
You can attempt to bleed it could be air in the cooling system or have it block and pressure tested
Sep 11, 2010 at 9:44 PM
