1993 Chevy Cavalier Oil Pressure Guage
159,962 MILES • 6 CYL • FWD • AUTOMATIC
ENDERZ05
i recently had my car fixed, it would drive fine and then just shut off. If started and left run it would run fine. It ended up being a bad TCC (torque cylinder converter). I also had a complete transmission flush. Now when i drive my oil pressure guage goes up and down. If accelerating of normal driving it registers between 40-50. When braking or at a stop it goes way down to almost zero. Car seems to run fine though. What could be the problem?
Jul 9, 2008 at 3:06 PM
  • 75,988 POSTS
If you're hearing engine noises better immediately check the oil pressure with a mechanical gauge-if normal replace the oil pressure switch-if not could be oil pump, engine bearings-etc
Jul 9, 2008 at 3:13 PM
