1993 Chevy Cavalier key ignition
13,700 MILES • 6 CYL • FWD • AUTOMATIC
PATTYJO
my key is stuck in my ignition. it will turn and run but sometimes the car will shut off while driving. does this have anything to do with the key not coming out. I had a new computer put on,plugs and plug wires. it takes a couple of times for my car to start when i have driven it and shut it off. i was told he was because my key is stuck
Aug 19, 2010 at 6:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the ignition switch is probably at fault here which is why the key sticks sometimes and also can cause the engine to die if it's faulty.
Aug 19, 2010 at 9:58 AM
