1993 Chevy Cavalier heats up in the morning
190 MILES • 6 CYL • FWD • AUTOMATIC
JD182
When we first start it and take off, the temp will increase until it pegs out, sometimes the check gauges light even comes on. The heater will start to work and temp will run fine. Every now and then it will do this two times. Once the engine is warm it will run normal. What is causing this?
Jan 22, 2009 at 9:47 AM
RHALL77
  • 3,361 POSTS
check and make sure your coolant is full. also it could be caused by a bad thermostat.
Jan 22, 2009 at 9:52 AM
