[quote:8d7a053a70="kuhl21"]The coolant is good. We took the thermostat out because we hit a deer and there isn't enough pressure in there.[/quote:8d7a053a70]
well you need the thermostat back in
that will keep the engine running at the norm temp
engine will operate at best when reach it norm temp with out the thermostat engine will run like older carburetor car would when choke is on very rich
I m sorry
I still don’t get the pressure issue
if you hit a deer I would say you may have a damage radiator
causing it to leak the coolant
you don’t solve that by removing the thermostat
Jan 31, 2008 at 12:54 PM
