1993 Chevy Cavalier fuel in air cleaner
LEFTYS4JS
Smells problem
1993 Chevy Cavalier 6 cyl Front Wheel Drive Automatic
just bought a 1993 chevy cavalier z24 3.1L it wont start unless you hold the pedal to the floor..it runs great once started.the guy said it needs a new fuel pressure regulator ...smelled gas under the hood notice there is gas running into the air cleaner is this still the problem or am i looking at something else
Apr 7, 2008 at 12:35 PM
BMRFIXIT
  • 19,053 POSTS
gas leak is a serious issue
and you need to take care of it immediately.
you may check the pressure regulator by removing the vacuum hose off of it and if you have fuel present then its no good and need to be replaced
Apr 7, 2008 at 12:48 PM
