4-Cylinder Engines
Disconnect the negative battery cable.
Remove the air cleaner duct.
Detach the wiring harness from the motor and the fan frame.
Remove the fan assembly from the radiator support.
Position the fan assembly to the radiator support. Tighten the fan assembly motor-to-fan to 29 inch lbs. (3.2 Nm) and fan-to-radiator support bolt to 80 inch lbs. (9 Nm).
Connect the fan electrical wiring harness.
Install the air cleaner duct.
Connect the negative battery cable.
Aug 18, 2009 at 5:24 AM
