1993 Chevy Cavalier Dead Battery
LVE1023
Electrical problem
1993 Chevy Cavalier 4 cyl Wheel Drive Type unknown Automatic 89000 miles
After turning off the engine something is draining the battery within usually about 10 hours. We have a new battery, unhooked light in trunk and glove box and have the dome light turned off. Any suggestions?
Mar 5, 2008 at 2:07 PM
  • 75,988 POSTS
Disconnect the negative battery cable put a test light between the cable and negative battery post-If there's a short the test light will lit-now start removing fuses one at a time-the fuse that eliminates the light is the trouble circuit.
Mar 5, 2008 at 6:46 PM
