1992 Chevy Cavalier Valves
223,423 MILES • 6 CYL • 2WD • AUTOMATIC
RAPMRG
hey... Me and my buddy took apart his upper motor to replace the intake manifolds, and to clean up the inside of the engine. but were basically finished. all we need to do now is take off the lower intake manifold and replace it, but the process involves disconnecting the valves and rods. ive been looking for the factory specs for the valves once everything is replaced. is there a way u could help me find all the info on it to make sure we put everything back together correctly?
Mar 16, 2009 at 5:13 AM
THETOOLMAN
  • 123 POSTS
The valve train is pretty simple. You just take off the the rocker arm assembly and use a piece of card board or something to keep each item in the order that you remove it. So when you put it back on you can put it all back on the head and side it came off of. There is no valve adjustment because they are hydraulic. I figure that is what you mean by valve specs? You just tighten the rocker arm down to the specified torque.
Mar 16, 2009 at 5:33 AM
