1992 Chevy Cavalier swithc auto trans for a munual
TMCC90
  • 1992 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 192,000 MILES
What would it take for me to put a standard trans in my stock automatic.
Wednesday, May 5th, 2010 AT 8:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating!
There are a lot of steps involved in this process. Follow the major steps below and if you get stuck along the way just let us know and we will help you out more.
Remove the existing gear shift linkage, if it is a column shift, or the shifter, if it is floor-mounted. If it is a column mount, use a small hammer and tap out the roll pin holding the gear shift lever. Remove the shift cable from the lever at the base of the column and pull it through the firewall. If it is a floor shift, it will be necessary to remove the center console and take the shifter loose from the floor. Simply unscrew the bolts holding the console and the floor shifter to the floor.
Unbolt the brake pedal linkage from under the dash. Disconnect the electrical connector to the brake light switch. Bolt in the new clutch and brake pedal assembly under the dash. Bolt on the new brake light switch and connect the electrical connector.
Raise and support the vehicle on four jack stands. Remove the gear shift cable or linkage from the transmission by removing the nut on the linkage and pulling the gear shift lever off. Save the gear shift lever for later installation.
Disconnect the torque converter by removing the inspection cover with a wrench and removing the bolts in the torque converter using a 3/8-inch drive ratchet and socket. Remove all electrical connectors from the transmission. Remove the bolts in the drive shaft yoke using a wrench. Remove the drive shaft.
Place the floor jack under the transmission pan and remove the bolts in the cross member and transmission mount using the ratchet and socket. Lift the transmission and remove the crossmember. Lower the transmission and remove the transmission cooler lines with a wrench.
Remove the bolts in the bellhousing with a ratchet and socket and remove the transmission. Remove the flexplate using the ratchet and a socket.
Install the new flywheel and tighten the bolts. Install the new clutch kit using the alignment tool that comes with the kit. Tighten the bolts securely. Install a new throwout bearing in the new bell housing and bolt up the new bell housing.
Bolt the new manual transmission to the bellhousing by inserting the bolts and tightening them with a ratchet and socket. Plug in all electrical connectors.
Install the transmission mount and tighten the bolts with the ratchet and socket. Place the floor jack under the transmission and raise it to install the crossmember. Lower the transmission onto the crossmember and insert the bolts and tighten. Install the driveshaft and bolts and tighten with a wrench.
Pass the linkage or cable through the firewall and attach it to the clutch pedal. If it is a hydraulic clutch, attach the master cylinder to the clutch pedal and the firewall. Bolt the transmission-end of the linkage or cable to the clutch release rod on the transmission. If it is a hydraulic system, attach the slave cylinder to the transmission.
Install the shift lever on the transmission by putting the nut on the shaft end and tightening it with a wrench. With your hand, put the shift lever on the transmission in the neutral position. When it is in neutral the drive shaft can be turned by hand.
Remove the top cover plate on the transmission if it is a top loader. Bolt up the shift lever and cover. Cut a hole in the floor for the shifter, if it is a side mount shifter. Bring the shifter and stick the handle up through the floor and insert the bolts through the side of the shifter holding it to the transmission. Tighten the bolts with a ratchet and a socket. Bolt the linkage from the shifter to the shift levers on the transmission. Make sure the shift and the transmission shift levers are both in neutral.
Thursday, May 6th, 2010 AT 12:59 AM
