Need to contact local locksmith or your Chevrolet dealer. You will need to give them your Vehicle Identification Number. A blank key usually costs around $5.00 then another $15 - $30 to have it cut out. Newer model vehicles now come standard equipped with security systems which include a chip inside of the key. Only a few pre-1996 models were equipped with this feature so I do not know if your vehicle has this or not. If it does, the cost becomes much greater to replace, usually costing around $130 to have the key cut and programmed to your vehicle. The dealer or locksmith can have the key made within minutes.
Thanks for using 2CarPros.com!
Mar 22, 2021 at 11:00 AM
