The problem started with a relay ticking in the engine and a sound that seems to be the air compressor going on and off and ended with a crack in the radiator and what I discovered later, a fried radiator fan motor
Already replaced:
-radiator
-radiator fan motor
-cooling temp. sensor
-clicking relay (passenger side, first one behind the shock mount as you face the car)
When I turn ON the engine and turn ON the air condition the radiator fan does not turn, the clicking noise goes on. I know from other cars that radiator fan must go ON as soon as you turn the air condition on. What else can I test or look for. Please help. I am out of ideas...
Thank you,
George
Already replaced:
-radiator
-radiator fan motor
Thank you,
George
May 26, 2009 at 3:03 PM
