1992 Chevy Cavalier knock sensor
68,000 MILES • 4 CYL • FWD • AUTOMATIC
BOOMERLT
where is the knock sensor located on a 92 chevy cavalier with a 2.2 liter and also i am doing an engine swap on a 94 chevy corsica and the crankshaft position sensor is different if possible i am trying to find out what the three wires do on the 94 2.2 thank you very much
Oct 8, 2009 at 5:59 PM
JDL
  • 16,098 POSTS
welcome to the forum, usually with engine swap, you get the engine and computer from donor vehicle. No knock sensor listed for 92 vehicle. 94 crank sensor connector, brown wire is voltage feed to sensor, red wire shows to be ground, yellow wire is sensor signal to the computer.
Oct 9, 2009 at 2:37 AM
BOOMERLT
thank you very much and thanks for taking the time to answer my questions.
Oct 9, 2009 at 4:58 AM
