1992 Chevy Cavalier Ignition key lock
TIM_META
Steering problem
1992 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 130k miles
There are some press in rivets in the steering column that hold the lock cylinder to the column.
No access to the bottom. The bottom of the hole is covered by aluminum casting. I have good photos
help![img:a3bf2fcd31]http://www.2carpros.com/forum/automotive_pictures/572375_auto_002_1.jpg[/img:a3bf2fcd31]
Sep 13, 2010 at 4:17 AM
TIM_META
I guess these are shear bolts and need to be drilled and then easy-out reverse thread bold remover
bummer
Sep 13, 2010 at 5:32 AM
