1992 Chevy Cavalier how to pull codes?
220,000 MILES • 4 CYL • FWD • MANUAL
SMOKINNPHX
i have a major hesitation in the motor especially when accelerating it loses power runs really rough replaced the coils, spark plugs wondering if the check engine light has something to do with it. too old for standard code reader was wondering if i can use a paperclip or something like that and where to use it at
Oct 31, 2009 at 10:23 AM
  • 75,988 POSTS
Jumper A to B
https://images.2carpros.com/forum/automotive_pictures/12900_GM_ALCL_44.jpg
Possibilities: Oxygen sensor Dirty fuel injectors (cleaning the injectors often fixes this). Bad MAP (manifold absolute pressure) sensor Bad TPS (throttle position) sensor Bad or dirty MAF (mass airflow) sensor Low fuel pressure (leaky fuel pressure regulator or weak fuel pump) Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve) Bad gasoline (fuel contaminated with water or too much alcohol) Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include: Dirty or worn spark plugs Bad plug wires Weak ignition coil Wet plug wires
Oct 31, 2009 at 10:48 AM
