1992 Chevy Cavalier How do you replace the ECM in a 1992 Ca
180,000 MILES • 4 CYL • FWD • AUTOMATIC
IRONRING1
I was wondering how one would replace the ECM in a 1992 (VIN 4) Cavalier. In my Haynes manual, it talks about a PROM unit, and shows it under a removable flap on the ECM case, but I cannot see any such flap. Is there a PROM in the ECM for this car that needs to be put in a new ECM, or can I just swap in a different ECM?
May 2, 2008 at 5:27 PM
BMRFIXIT
  • 19,053 POSTS
Usually the new ECM does not have the PROM in it
and you have to remove it from old ECM
if I recall correct the ECM have two screws you remove
( the access cove to the PROM
if you have a (used) ECM
you can just swap them
May 3, 2008 at 11:50 PM
