1992 Chevy Cavalier fuel leaking
122,000 MILES • 4 CYL • FWD • AUTOMATIC
RFINNAN
noticed fuel smell, #1 injector leaking. Replaced injector all was well for a week. Noticed smell again #2 was leaking not surprised had a notion that it may have been in trouble. Replaced #2 started car. It was running rough and notice gas smell. Upon checking fuel was on the ground and noticed fuel running down exhaust pipe. Upon further inspection saw gas blowing out of where the exhaust pipe connect to the exhaust manifold and fuel was being pushed out the muffler. Pulled #2 spark plug and it was totally black. What is going on.
Mar 30, 2009 at 1:59 AM
BILLYMAC
  • 2,204 POSTS
i would put the other two new injectors.. and a new fuel inj temp sensor. injec are stuck open in one cyl
Mar 30, 2009 at 2:25 AM
RFINNAN
[quote:0addd71d07="billymac"]i would put the other two new injectors.. and a new fuel inj temp sensor. injec are stuck open in one cyl[/quote:0addd71d07]
other injector are less then a year old, and where is fuel injec temp sensor
Mar 30, 2009 at 2:39 AM
BILLYMAC
  • 2,204 POSTS
temp sensor in or near thermostat housing in the cooling system
Mar 31, 2009 at 8:52 AM
