1992 Chevy Cavalier cigarette lighter
KENDRA625
Electrical problem
1992 Chevy Cavalier 4 cyl Wheel Drive Type unknown Automatic 156800 miles
hello.. i was wondering if the reason my lighter isnt heating up was due to a fuse needing changed? i would like to use an adapter to power an mp3 player and the cigerette lighter hasnt worked, so i cant use an adapter.
thanks so much.
Mar 21, 2008 at 12:55 PM
MASTERTECHTIM
  • 4,750 POSTS
yes. most likely the fuse is blown. if not then the lighter housing may need to be replaced. do the interior lights work?
Mar 21, 2008 at 1:28 PM
KENDRA625
the interior lights work. the cigarette lighter and also the windshield washer fluid doesnt come out either. i have it filled to the line and im hoping that as well is a fuse? its not overly important to have fixed, but its one of those nuisances.
thanks so much tim!
Mar 24, 2008 at 7:31 AM
MASTERTECHTIM
  • 4,750 POSTS
well the two are not releated. you will need to check power and ground at both the windshield pump motor and the cigarette lighter and probably replace the 2 of them
Mar 25, 2008 at 11:05 AM
