1992 Chevy Cavalier Car won't start ECM Fuse blown
149,000 MILES • 4 CYL • FWD • AUTOMATIC
GTRGILBERT541
  • 14 POSTS
today my car just quit while on my way to work. i had it towed to a mechanic and he looked over everything. replaced all fuses replaced all relays changed the crank sensor, made sure the fuel pump was working replaced ecm and the car still won't start, so next we tested the car for engine codes and it said no communication with module any help would be great
Oct 1, 2008 at 1:27 PM
2CARPRO JACK
  • 11,533 POSTS
If it wont communicate there is still a problem with the ecm or the wiring to it. Is there power at the diagnostic connector? if so you need to do a pin to pin voltage test at the ecm to determine what is missing. Could be a bad wire or connection somewhere.
Oct 3, 2008 at 1:13 AM
GTRGILBERT541
  • 14 POSTS
Thanks was a wire that burned into
Oct 5, 2008 at 3:47 AM
2CARPRO JACK
  • 11,533 POSTS
Good find..
Oct 6, 2008 at 12:46 AM
