1992 Chevy Cavalier
DUCE01
1992 Chevy Cavalier 4 cyl Front Wheel Drive Manual
when i press the gas peddle to the floor it bogs down... but if i feather it drives but only goes 30 mph??? i have changed the fuel pump, fuel filter, oil,and got catalytic convertor checked,and changed oil filter... what else could it be that is causing this...
Sep 8, 2010 at 7:53 PM
  • 110,251 POSTS
Have you checked for vacuum leaks? Has the check engine light come on?
Sep 9, 2010 at 12:36 AM
DUCE01
engine light not on,how do i check vacume leaks,is there a diagram to show me how to rerun them?
Sep 9, 2010 at 7:20 AM
  • 110,251 POSTS
There are vacuum hoses on the engine. Check for cracks, dry rot, disconnected ones... Also, I can get a schematic, but when it is uploaded, it's too small to read.
Sep 10, 2010 at 12:33 AM
DUCE01
OK,CAN I NOT ZOOM THE SHEMATIC TO MAKE BIGGER AFTER I DOWNLOAD,and thanx
Sep 10, 2010 at 7:37 AM
  • 110,251 POSTS
I've had others try and it doesn't work.
Sep 10, 2010 at 5:24 PM
