1992 Chevy Cavalier
OHIOUKITTY
Electrical problem
1992 Chevy Cavalier Engine Size unknown Front Wheel Drive Manual 150000 miles
when i start the car, it almost immediately stalls.... when in gear. sometimes it will buck me in 1st and 2nd, then shut down. the last two days i would have it on the interstate and at 65mph the car would start to seem like it was shutting down, no matter what.... it would also try to buck me at that speed. i am not sure if this is a clutch issue or an electrical short comming that i can get help with. thank you so much...
chrissie
Mar 23, 2008 at 10:33 AM
  • 75,988 POSTS
Check the idle air control valve/throttle position sensor/fuel pressure and exhaust system for restriction
Mar 23, 2008 at 11:26 AM
