I have a 91 Chevy Cavelier that runs fine until you shut it off and it cools for about 20 minutes. The fuel pump and injectors have been replaced as well as fuel pressure regulator, MAP sensor, TPS sensor, crankshaft sensor, oxygen sensor, temp. sending unit, ignition control module, fuel pump relay, also recently car has started stalling while driving at highway speeds. Any help would be greatly appreciated
Nov 20, 2007 at 9:59 AM
