1991 Chevy Cavalier transmission problem
104,000 MILES • 4 CYL • 2WD • AUTOMATIC
NANCY HENDERSON
My car will come to a stop and cuts off. When I put it in park to start it up, it starts but jerks hard when I put it in drive. Sometimes it will cut off again. Roughly how much will it cost to get is fixed and is it the transmission? I have already did a lot of maintenance on the electrial side of it. etc. plugs, wires, computer module, and coil.
May 24, 2010 at 3:43 PM
MMPRINCE4000
  • 8,548 POSTS
Classic symptoms of TCC solenoid sticking (torque convertor clutch lockup solenoid).
Generally they can be replaced without removing trans.
Look for a white or blue square weather-pak connector on trans, try unplugging it first, if problem persists, change TCC.
May 26, 2010 at 1:19 AM
