My Cavalier will run for 20-40 minutes and then stall once to a stop. when you try to turn the car back on, it will work until you switch from park to neutral, reverse or drive, then it will stall again. If you let it sit for quite some time, it will do the same thing all over again.
Aug 1, 2010 at 7:59 AM
