I've noticed that the car is using a lot of antifreeze?
308,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAMANTHAP
Recently I just replaced the thermostat in my car. And now I've noticed that the car is using a lot of antifreeze. In one week it drained the overflow, but yet I do not see a leak. Also when the car is idle it has a bit of smoke coming out from under the hood. I opened the hood and it is coming from the rad. What could this be?
Dec 14, 2007 at 6:51 AM
  • 75,988 POSTS
Have the cooling system and pressure cap- pressure tested this will tell if you have internal combustion leakage.
Dec 14, 2007 at 7:15 AM
  • 55,808 POSTS
Yep, you probably have a blown head gasket. Here is a guide to help.
Please go over this guide and get back to us.
Oct 7, 2024 at 10:50 AM
