1991 Chevy Cavalier idle speed
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
ACE20368
heres my question i know the idle speed is controlled by the ecu. so how can you change the idle speed do you have to use a gm scanner. like if you replace the ecu how do you adjust idle speed. and where can i find information about it. need help please
Mar 1, 2009 at 5:38 AM
  • 75,988 POSTS
Try cleaning the idle air control valve it provides an input signal to the computer to target the idle speed.
Mar 1, 2009 at 6:40 AM
